That’s the beauty of the whole concept.<p class="MsoNormal"><![if !supportEmptyParas]><![endif]><o
></o
></p><p class="MsoNormal">Thanks to “You Tube”, I can test the smoke unit with all the audio systems out there; and even with the real engines…</p><p class="MsoNormal"><![if !supportEmptyParas]><![endif]><o
></o
></p><p class="MsoNormal">The marketing possibilities are also enormous:</p><p class="MsoNormal"><![if !supportEmptyParas]><![endif]><o
></o
></p><p class="MsoNormal">Let say, for example; that you want to know what the smoker would look like in your new tank: All you have to do is put your tank on a block and post a video on you tube.</p><p class="MsoNormal"><![if !supportEmptyParas]><![endif]><o
></o
></p><p class="MsoNormal">In return, the dealer could post back a video with the smoker hooked up to your tank soundtrack.
</p>
