RCU Forums - View Single Post - NGH 9cc
Thread: NGH 9cc
Old 07-03-2013 | 07:27 AM
  #146
disljenko's Avatar
disljenko
Default RE: NGH 9cc
ORIGINAL: earlwb
I have three of the little 9cc engines in use and they went through more than four gallons of fuel since I first started running them. That is a fair amount of flying considering how much fuel they consume per flight. The engines are still hanging in there OK. I used the Amsoil Saber pro oil at first, but it was carboning up the head and piston more than I liked, so I switched to Stihl Ultra synthetic oil instead. I feel that one needs to use a really good oil, preferably synthetic in order to ensure longer life out of the engines. The connecting rod is the main weak point as it doesn't do well with cheaper oils.
Earlwb since you mention oil i have one question. I also have ngh 9cc but i realize that from my muffler exit alot unbrned oil (black stuff). I use 5% oil mixture but i wonder if this black oil from my mulffler indicate that mixture have more oli that engine acctualy need. Can i reduce oil mixture to 4% without damaging engine. Higher oil ration reduce engine power, i sow in spec for this engine oil ratio is 4-5%. Almost forgot i use Stihl oil but dont now what type( it came in small bottles - 100ml) !!!!
Thanks in advance !!!!<br type="_moz" />
