RCU Forums - View Single Post - Nitro direct drive
Old 07-03-2013 | 09:05 AM
  #33
Anthoop's Avatar
Anthoop
Default RE: Nitro direct drive
120 is the record for nitro....as in anything....there are different classes....from memory the record is not even from the "open" class....not too sure if your car would fit into the "open-wheel" class or it would go into "open"(because of the my bad memory of the specific class rules). If you are interested in comparing/making a record then all the info. is in the links I gave earlier and if you want help with wheel/suspension setup info. and generally any info. concerning speed running then there are other forums where the people making/recording the records will help....again should all be in the links.
Above all...good luck and have fun.
