What do you guys want? I have taken all the sections of Clarks Info and put them in PDF files so they are easy to mail. I did this by application too so it seperates some of pages. I find it helps because everything doesn't bleed together so much.<div>
</div><div>Panther G the servo mod will do well with your needs for traverse, the elevation you probably won't need to mod the servo. Once plugged into the pins on J4 all you need to do is set the board to run elevation from the servo.</div><div> The Clark TK22 will give your barrel about 30 to 40 rise without end point adjustments.</div><div>
</div><div>Here is a good listing of how the left stick operates and some reciever plug ins. As long as you remember channel 3 on the Clark board is usually throttle on the reciever you can get the other 3 wires.</div><div>
http://www.immortalhobbies.com/Clark_Board_Set_Up.html</div><div>
</div><div>
</div><div>
</div><div>
</div>
