ORIGINAL: turok007
are you sure the garmin is in the right setting as i have the 301 and it took a while to get it right. on mine i can set 3 things like top speed average speed and distance. and i have to press start before the run. also if you plug it into your PC you can see what speeds you were doing. and you can overlay you run onto google maps.
i did just get It today so maybe I'm missing something but I tried to go into settings only thing I did was change from "pace" running mode to "speed" cycling mode so it will get mph. I also press start when I do a run then hit stop once I'm done. Anyway on this one it doesn't look like you can connect to pc so I'm going to get the 301 and see if that works.
