ORIGINAL: rcpete347
HI all, a friend of mine worked in the transit garage, working on bus transmissions, for most of his career.He was constantly getting tumors on his hands.
Back to jets, burn less oil, like Jet Central, or do what I suggested , years ago, put a dedicated oil system in our turbines, not rocket science.
Rcpete
Not sure why you would want to put a dedicated oil system for.
Maybe just to complicate things more and add extra weight not to mention something else to go wrong.
Personaly I like the way we mix the oil ourselves as it is fool proof for as long as you do the rite. mixture. Does not take a genius to work out.
I use Mobile jet 2 for my turbines and will always keep on using turbine oil for turbines no matter what MSDS says. Everything is dangerous this is why there are SWMS and MSDS so the appropriate precoutions can be taken.
I think if I'm going to die from cancer it will be from the partying I did in my younger days , the days I spend in the great out doors, and/ or the fumes I breath every time I go outside.
<br type="_moz" />
