RE: Throttle connection question.
Steve, here's what Futaba says about using a metallic type of throttle pushrod. Send an email to your RC manufacturer and listen to what they say before you do what someone on RCU recommends. Dan.
Guidelines for setting up gasoline engine models.
All ignition equipment, including an electronic kill switch, must be mounted at least 12", and preferably 14", away from all radio equipment, including throttle servos, etc. Ignition kill switch should always be on opposite side of fuselage from radio kill switch. All pushrods going to anything related to the engine must be non-conductive (just nonmetal clevises is not sufficient).
