RE: GSU on P90-RXI
Try and change the ribbon to the other plug on the I/o board. They are interchangeable. I have seen hyroglyphics on my gsu before and this seems to cure that. Also you can unplug and replug the ribbon connector into the ecu. This will help also as the small ribbon that connects the I/o bard to the ecu is very finicky.
