RCU Forums - View Single Post - Throttle connection question.
Old 07-06-2013 | 08:20 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: Throttle connection question.
ORIGINAL: JRgraham
ORIGINAL: acerc
Lets see, every piece of lawn equipment- metal to metal, every piece of hand held lawn equipment-cable or rod pull and spring return. Now let's for just a moment say any metal to metal will cause RFI, now lets say for that same minute that every piece of that engine is metal rubbing metal, if metal to metal caused interference then every moving part of that engine, ring to wall, ring to piston, rod to piston, rod to crank, and all the bearings or bushing in between, man that is a lot of metal to metal !!!!!!! Hmmmmmm?????
Iknow you know your stuff acerc, but how can you compare lawn equipment's mechanics in this kind of discussion.. unless you use a remote control on your mower and edgers?? There are no receivers in those things, so Ido not think it really compares. Otherwise, your right on! lol
Please tell me you don't actually think there is metal to meatal contact within an engine?
