RCU Forums - View Single Post - Ballerina 1/3 scale by hacker-model.com
Old 07-07-2013 | 01:56 AM
gadix's Avatar
gadix
Default RE: Ballerina 1/3 scale by hacker-model.com
hello to all
have did some progress with the engine mount...took a while as the original stands are longer than the distance you will need to be clear with the cowl and spinner plate...should be 20.7 mm!!
this is the smalles gap i could get as the engine mounts and air/fuel needls should have good accses...!
did some dremel-ing for cowl and air cool passes in the fuse...
also, have uinstalled "toilet setting lid" as the wing bolt to the fuse - works great!! very cheap at any DIY
enjoy
ID:	1898282   Click image for larger version
ID:	1898283   Click image for larger version
ID:	1898284   Click image for larger version
ID:	1898285   Click image for larger version
ID:	1898286   Click image for larger version
ID:	1898287   Click image for larger version
ID:	1898288   Click image for larger version
ID:	1898290   Click image for larger version
ID:	1898291   Click image for larger version
ID:	1898292   Click image for larger version
