RCU Forums - View Single Post - Stingray problems!
Old 07-08-2013 | 11:27 AM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Stingray problems!
At neutral stick, you need quite a bit up "pitch up" trim on the elevons, probably 1/8 inch if memory serves.
If you took off with the elevons even with the trailing edge of the wing, that would explain the big pitch down "feel" you experienced.
EDIT your thrust line should be fine. CG is somewhat critical for good landing performance.
