RE: Motor Timing Question
Usually timing is set at around 28 degrees.(ie no advance /retard)
Motor usually runs at or near a rev range where this is about the best setting.
I don't know about your particular engine but most magnetos will run a magnet to induce the coil with a charge and the remaining magnets helps to collapse the charge field as the spark is required.
