RE: New Be needs help tuning or trouble shooting
In my experience, once you start to "fiddle" with the metering arm you're screwed. Without the proper equipment (depth gauge & pressure tester) you will spend hours taking the carb off, tweaking, putting it back on, testing, then repeating the process.
What brand carb is on the engine and what is its displacement?
BertZ
