RCU Forums - View Single Post - esc problem?
Thread: esc problem?
Old 07-10-2013 | 08:14 AM
flatpickhippster
Default RE: esc problem?
Your ESC plugs into your RX. The RX is binded to the TX. Tx talks to RX which talks to ESC/Servos
Sounds like you have a bad RX.....is it a Spectrum or different?
Does your TX have memory for multiple vehicles? I've seen some binding issues arise when binding Tx/Memory slot w/ existing settings loaded into the memory. If you do have memory slots, try starting with a blank or delete any settings in memory your trying to bind from.
Good Luck
