RCU Forums - View Single Post - THE FIELD BOX FROM HELL! aka The Ultimate Field box!
Old 07-10-2013 | 11:08 AM
  #589
Robert A.'s Avatar
Robert A.
Default RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box!
Hi
I've been reading this thread and decided to make my own FBFH but as I'm fairly new I need some help with the plumbing and fittings. I have a Prolux MKIII power panel which has a inbuilt pump (in and out feed). I also have 2 fuel cells for 2str and 4str. I don't know how to plumb it up and what easily bought fittings (I'm in the UK so any common type fittings) I need? I have seen so many variations in here (mainly with the number of pipes which go into the fuel cells). I thought to have one feed from each cell to the front of the field box, then a feed which can be switched from 2str to 4 str to the pump and then the feed from the pump to the carb. I don't know if this will work as I see alot of fuel cells with 2 tubes (I think maybe something to do with either a vent or one way valves?). I also don't know what fittings I need to make this work (the fittings for the fuel cells, the front of the field box and anything else I don't know of).
Hope someone can help.
Rob
