RE: Runway take off trouble
Actually standing to the side allows you to see the angle of attack of the wing so you do not stall on takeoff . Standing from the back only tells you if you are going straight on the ground .Can not see any angles that is a bad habit of modelers and sells a lot of arfs if you build you tend to be more careful and put more effort in making them last and understanding theory.
