RCU Forums - View Single Post - Top Flite Staggerwing
Old 07-11-2013 | 05:51 PM
  #1834
Staggerflyer's Avatar
Staggerflyer
Default RE: Top Flite Staggerwing
Apparently you guys are using a different unit than I did. I used the one specified in the instructions, which had a plastic actuator horn. I did not have any problems with the retract unit itself. I used the separate air ram mounted up by the servos. Never a problem, once I got the doors to open. Up or down. The only problem I had was not enough turn radius/movement.
