RCU Forums - View Single Post - Can you make ailerons act like flaps using mixing?
Old 07-11-2013 | 05:56 PM
tschuy
Default RE: Can you make ailerons act like flaps using mixing?
yes it is possible to mix flaps with ailerons. It would be helpful if you'd share what radio you are using and then some of the mixing experts can step in and point you into the direction on how to mix. another thing you may do is to read your owners manual for your radio and it may have the information you need in that documentation.
