RCU Forums - View Single Post - SPEED
Thread: SPEED
Old 07-11-2013 | 10:41 PM
Henke Torphammar's Avatar
Henke Torphammar
Default RE: SPEED
ORIGINAL: highhorse
ORIGINAL: paulhelis
hi amigos i did tested with the ultrabandit and yes its a lot more fast
what do you think? i didnt used the mammoth speed sensor to compare,
next week i will do it, to see if the speed displayed are near each other
thanks
That one is almost without question a sample rate induced GPS spike. Ie, false indication. 354 mph is quite a stretch.
Does it use GPS? For a GPS reading you would need the whole log file and check the level flights for a sort of avarage. As it states airspeed I assume GPS was not used with the iGyro
