RE: Inverted OS .46 Floods
Years ago I bought a Cline regulator for a similar problem. Never got the plane running right with the cline. Additionally, the install requires drilling a hole in the engine back plate and installing a pressure fitting. Then after one discovers that the Cline doesn't work, that hole has to be plugged. And there must be room in the cowl to mount the regulator next to the carb.
