RE: Inverted OS .46 Floods
Aug,
Here's one more idea ...
Replace the "O" ring on the high speed needle. If this "O" ring dries up, or is damaged, your engine will never run or idle right. Plus, this could be the reason fuel leaks through the carb.
I have several planes with inverted OS engines. I never had the problem you describe.
