ORIGINAL: jonlowe
Jim,
I've tested it on the ground, but not flown it yet. Seemed to work fine.
BTW, on the bottom of the board, there is a square, flat black device, not an IC. The black plastic cover was broken on the device on the esc in question, but the coil inside was not hurt at all. I tried the numbers on the device, but couldn't come up with anything. I think it is an inductor, but I'm not sure. Only has two solder points. I think the lettering on it was L101, and then .g3c or something like that below it. Do you know what it is?
The part is clearly marked F101 g2D on mine. It could be a fuse but probably an inductor. If it works, fly it.
Jim O
