RE: 6th Marine Tank Battalion M4A3 Sherman
Thanks!!! For the tracks on the outside I the plastic tracks from the HL Sherman (thanks Jeff). I cut off the teeth. It looked in photos like the Marines had removed them prior to welding. I used hobby grade CA glue and used insta-set. They are holding firm. If they stop holding I will probably resort to plastic weld or epoxy putty. I would prefer not to have to drill and screw them on. I had to separate the links at the seam in the front plate. The sandbags are hand made using epoxy putty, a square of ladies hose and khaki paint.
