RE: Top Flite Giant P-47 Build
Little more progress.
Fuse is completed.
Servos installed in the tray. Rear wheel installed.
I have a question. The 32 oz Du-Bro tank when installed right against the firewall touches the servo tray in the back of it.
Did you guys had a similar problem? How did you go about it?
Also when mounting the servos on the tray, the mounting screws on the elevator and rudder servos facing the back of the plane are installed right into the servo tray rail which makes it a real pain in the &(@(; to remove the tray to access to the fuel tank for maintenance, since you have to remove all the servo screws in order to take the tray out.
Any solution to that?
Thanks for the help.
Fabio
