RE: wall charger and 6V - NiMH battery
The charger in question is most likely rectified AC without much if any filtering. The average voltage you read with a DC voltmeter is quite a bit lower than the peak voltage. The peaks will charge a battery to a level higher than what you read a
s the average voltage
