You can use up to G size model rocket engines provided they stay attached to the aircraft.
You can't launch rockets from a model.
To be clear, that's what the AMA safety code says, which is not a law, just a guideline to remain compliant with insurance and common sense safety practices.
Club rules and local ordinances may be more restrictive.
2. Model aircraft pilots will:
(a) Yield the right of way to all man carrying aircraft.
(b) See and avoid all aircraft and a spotter must be used when appropriate. (AMA Document #540-D-See and Avoid Guidance.)
(c) Not fly higher than approximately 400 feet above ground level within three (3) miles of an airport, without notifying the airport operator.
(d) Not interfere with operations and traffic patterns at any airport, heliport or seaplane base except where there is a mixed use agreement.
(e) Not exceed a takeoff weight, including fuel, of 55 pounds unless in compliance with the AMA Large Model Aircraft program. (AMA Document 520-A)
(f) Ensure the aircraft is identified with the name and address or AMA number of the owner on the inside or affixed to the outside of the model aircraft.
(This does not apply to model aircraft flown indoors).
(g) Not operate aircraft with metal-blade propellers or with gaseous boosts except for helicopters operated under the provisions of AMA Document #555.
(h) Not operate model aircraft while under the influence of alcohol or while using any drug which could adversely affect the pilot’s ability to safely control
the model.
(i) Not operate model aircraft carrying pyrotechnic devices which explode or burn, or any device which propels a projectile or drops any object that
creates a hazard to persons or property.
Exceptions:
Free Flight fuses or devices that burn producing smoke and are securely attached to the model aircraft during flight.
Rocket motors (using solid propellant) up to a G-series size may be used provided they remain attached to the model during flight. Model rockets
may be flown in accordance with the National Model Rocketry Safety Code but may not be launched from model aircraft. Officially designated AMA Air Show Teams (AST) are authorized to use devices and practices as defined within the Team AMA Program
Document (AMA Document #718).
