Rexman...cool name
What were your suggestions to them? Just wondering because I began a build on one that received a new stab construction design because of a stab failure (I think was yours since it matches about that time). Just wondering if they did some of what you suggested. Here is what they did with the newer ones...added a layer of AC Ply to the structure of the Servo Deck so the servo's had a stronger base to hold the screws and not have to run the servo screws all the way through the thick deck, down to where the pipe comes through the tail. Also, they lengthened the CF "H" bridge to run further into each side of the stabs. I also noticed metal flakes when I drilled through the "H" Bridge, which shows they put an metal core in the Bridge.
I understand and agree completely on the waiting thing...we are all waiting!!!
Rex
