RE: Noise suppression - Capacitance
Things are a little clearer now.......
So, and correct me if Im wrong.,....... Ineed a .1 microF ceramic capacitor.
If I solder one between the two motor leads/contacts, and one between each of the motor leads/contacts and the body of the motor...... then Im good to go?
One more question.......the motors Ihave have a kind of tight fitting metal sleeve around the body.
Has this any particular function other than keeping crap out of the motor?
Should I solder the capacitors to the sleeve or the actual motor casing?
p
