ORIGINAL: EDFJim
1/2 inch will not show much on the curve of the stabs
Moving the shaft 1/2" forward is not the proper fix, you need to also move the pivot bearings and bulkheads a 1/2" forward to maintain the lines of the aircraft. This is why it is not an easy fix and should be done by the factory.
