RCU Forums - View Single Post - mk17 starting problems
Old 07-16-2013 | 04:31 PM
ffkiwi
Default RE: mk17 starting problems
Fiery the attached scan from a 1995 MEW article may help you devise a suitable venturi puller (the article was about reworking the early model Veco 19-which had a similar tight fitting venturi insert)-the dimensions for the MK-17 will be slightly different-but the principle is the same. In your position I'd go for heating rather than cooling-as heat will soften any oil residue that may be acting as a seal between the two surfaces........
ChrisM
'ffkiwi'
