RE: US NATS Judging Certification
Thanks. A few more:
1) #10: flight path and track are not the same?
From the AMA guidebook:
Track: The trajectory or flight path of the center of gravity of the model with respect to fixed ground reference.
2) #23: the answer should allow for more than terms of percentage. While that is the word used in the AMA guidebook (If it is flown partially out of the area, the downgrade assigned should be proportional to the percentage of the maneuver that is out of the area.) the previous section talks about fractions and not percentages. I used the word "portion" and was marked wrong.
3) #32: snaprolls within a loop must be flown to preserve the loop _______ . Geometry is not an acceptable answer. It should be. "Radius" and "circularity" are acceptable - radius is part of the geometry and circularity describes the geometry. The geometry of a loop does not involve varying radii.
