I have been using their agriculture counterparts for year w/o much problems and if this is an isolated case,WELL... it happens....[&o]But some the guys stated in this and others forums that it was a comun defect and It may happens if the bolts screws came loose in flight. If this is the case Zenoahs should take a closer looks to this problem.
I read in others forums that some guys are using DLE mufflers with great result I may try it. That is a bad sign for Zenoah donĀ“t you think?
AB Bob : Dyscovey channel is a lot of fun too.....
