ORIGINAL: Slow and Steady
I removed the yellowing with painters tape about a year and a half ago. My method is low tech but it works and requires about a half role of tape. Apply about a 10'' peice of tape to the white/yellow area (do not apply to colored areas) of the plane and then peal it off. The yellow will come off with the tape. It took about an hour to make the plane look new again. While I have since sold the plane, I see it regularly and it continues to look new.
By the way, I had a 30cc gas engine on it and it was too much torque and power. If I were to do it again, I would go with a DLE 20. A fellow at our field flies with this set up and he can do most any 3d menuever with it. Kind of makes sense, being that it was designed for a 20 gasser.
Here's what he tried it must have worked
