RCU Forums - View Single Post - Larger Classic Pattern airplanes
Old 07-17-2013 | 04:50 PM
Atlanta 60
My Feedback: (18)
Default RE: Larger Classic Pattern airplanes
How about RC City?? They have a nice list and several of them would be way cool... [8D]
[link=http://www.rccityfl.com/SearchResults.asp?Cat=1821]RC City[/link]
You may be looking for something older than those?? What about that Dirty Birdy 2+2...
[link=http://www.bridiairplanes.com/hangar/bigdirtybirdy.html]Dirty Birdy 2+2[/link]
A side note:
I currently have a 1.20 NC on my 20 year old Goldberg Ultimate Bipe...After struggling for a long time with the low end on that engine (too lean then rich idle), I found the fix!!! Enlarging the air bleed hole in the butterfly was the cure!!! Not sure if you have this problem but my engine never would idle right...It would never go straight to a steady RPM at idle...It would initially be lean after chopping the throttle and then go rich...It wouldn't quit but was always "hunting" at idle rather than being consistent...Now she's straight!!
Here are some links in case your not familiar with the issue (you may not even have this problem but it bugged the crap out of me)
http://www.rcuniverse.com/forum/m_82.../tm.htm#825352
http://www.rcuniverse.com/forum/m_74.../tm.htm#749991
http://www.rcuniverse.com/forum/m_12...tm.htm#1247900
http://www.rcuniverse.com/forum/m_40...tm.htm#4093073
http://www.rcuniverse.com/forum/m_23...tm.htm#2318205
http://www.rcuniverse.com/forum/m_10...m.htm#10337572
http://www.rcuniverse.com/forum/m_75...tm.htm#7830508
I also removed the regulator ballist (did that first but didn't help the problem)...
