RCU Forums - View Single Post - Surging and popping on acceleration (#2)
Old 07-18-2013 | 04:48 AM
basimpsn
Default RE: Surging and popping on acceleration (#2)
ORIGINAL: mitchilito
ORIGINAL: basimpsn
Do a video of the engine during startup.
Not sure why I would want to do that. It starts up just great.
Sometime a video of the problem speaks for it self. I remember replacing a bearing in a old Ram 1000 engine but forgot to put back the spacers washers for the compressor causing a wide gap between the compressor and the compressor housing.
The Engine would start and idle but as it throttle up the engine hangs up
Another cause could be a fuel ring leak.
Or missing restrictor between the bearing lub pipe
compressor touching compressor housing
restrictor needed for the fuel ring.
All the about is JUST MY OPINION
