RE: Which Charger?
Thanx for all of your responses everyone. Ok, I have been doing a lot of research about chargers and it looks like I am going to go with the Turnigy Mega 300w 8s Balance Charger/Discharger, from Hobby King. The price is right and it allow me to charge 2 batteries at the same time. However the charger requires a power supply of at least 30 amps. Any suggestions for a power supply for this charger? What are you guys using for power supplies?
Charger details:
Note: You will need a power supply exceeding 30Amps for bench top use!
Features:
• Dual power output 150Wx2 (300W total)
• Supports Li-XX, Ni-XX and PB batteries
• Store up to 10 battery settings
• Large cooling holes on the top edge of the case
• Dual temperature controlled cooling fans
• Wide input voltage range (11~18VDC)
Specs:
Charging Output: 2 x 150W (300w Total)
Input Voltage: 11~18v DC
Charge Current Range: 0.1~7.0A
Discharge Current: 0.1~5.0A
Discharge Power: 2x50watt
Balance Current Drain: 200mAh/cell
Li-XX Cell Count: 1~8s
Ni-XX Cell Count: 1~27cells
Pb Battery Voltage: 2~36v
Battery Setup Memories: 10
Intelligent Temp Control: Yes
Cooling: Dual Fan
Weight: 903g
Dimension: 188x136x58.5mm
Includes:
1 x JST-XH balance board
1 x Alligator clip charge lead
1 x Tamiya style charge lead
1 x Jr/Futaba Rx charge lead
1 x 4mm bullet connector pig tails (fit your own connectors)
1 x Power input alligator clip pair
Thanx, Mark
