RE: Before you buy from Troy Built Models read this
Thanks for the offer Dale. This kit only had an issue on one side. The dihedral was off but the spar pocket was installed wrong as well. I had epoxied the nacelles to the center section and was installing the engines and outboard wing panels when I noticed it. The left nacelle was pointing down putting a huge amount of negative incidence in the engine thrust line and the outboard panel.
It was an "Ooops" at the factory.
The only thing I am trying to find now is a quality pilot and copilot that do not cost as much as the airplane itself. lol
