RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 07-19-2013 | 05:50 AM
  #389
MTK
Default RE: OS 33GT Gasoline Engine for Pattern
Venturi diameter is 12.5mm (1/2").... It's the same for all the 30cc class engines I have seen. The carbs only differ in how the pump is actuated (internal pressure port or external pressure tubing)
The "manifold" is actually the reed cage and its diameter is the same as the venturi
