RE: Which Charger?
4*60, I was going to convert an old computer 350W PS until I read the label an it only put out 18A, when the charger requires a min of 30A.
Trax de Max, can you explain further? Do you mean the required PS current rating depends the batteries maH rating and its voltage? For instance, an 8S battery rated at 5000mah X 29.6 v = 148W. So to charge this battery, it will only require 5A and 148W? Can you elaborate.....
Mark
