RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 07-19-2013 | 12:47 PM
  #391
MTK
Default RE: OS 33GT Gasoline Engine for Pattern
If you ever decide to take another look at gassies, the GT33 is the right one. Hatori makes a header for it (also fitsthe DLE30 and several others). It loves a load so prop it accordingly, supply adequate cooling to itand see for yourself. My GT33 set-ups are terrific with either the ESC 30G or 40G pipes. I am certain that the new 35G pipes will work the same
I've stopped looking for single cylinder engines in this size. I have found what's needed in highest level Pattern comp. There's minimal downside, if any.....maybe downlines. But I've seen electrics go faster in the downlines than my GT33 does
I am looking at the small twin just to see if other characteristics (vibes) can benefit and if there's a down side
