RCU Forums - View Single Post - NEXSTAR ARF .....PROBLEMS...PROBLEMS
Old 07-19-2013 | 12:49 PM
  #120
Photoman228
Default RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
The problem is that the engines are not center line mounted for some reason orinaccuratelymounted. So first check that. Mine was off to the left.<div></div><div>Also many have added 1/16"+/- shim under right side of engine (looking forward from tail) which will offset some of reverse torque you are getting. If you watch, notice that on landings the plane will track straight in idle which confirms it is not a gear alignment issue. However when half throttle+ is added you go right.</div><div></div><div>It's all about thrust and alignment at full power.
<div></div><div></div></div>
