RCU Forums - View Single Post - Need help with the apple
Old 07-19-2013 | 03:19 PM
YHR's Avatar
YHR
Default RE: Need help with the apple
I stole this from Darkiths website This shows the pin out arrangement that you need.
You just need identify the positive wire and make sure you always orientate the plug the right way around. You can splice your 5 pin plug onto the wiring Phil did. Just make sure you don't cross the wires and keep them in the proper sequence. I would suggest you use the red wire on your plug to indicate positive 5 volt power.
