ORIGINAL: mark IX
Most of the time I will be using 6s 4000maH batteries. Or I could use 2 4s batteries if I need to go to the 8s size for larger models. Do you think the 6s situation would be better?
Mark
Personally I always think a single battery is neater than two smaller ones.. my Gaui 550 used two 3S batteries but I ended up swapping to a single 6S.. just easier to charge etc..
My Gaui X5 Heli uses 6S 4000Mah (40C) and I have only ever used the Accucel 8 to charge it..
It maxes out around 6.7amps and usually takes 35-40 minutes.. Never had an issue.. I'll make a video for you.
