RCU Forums - View Single Post - Electric smoke install
Old 07-20-2013 | 06:40 AM
DrScoles's Avatar
DrScoles
My Feedback: (18)
Default Electric smoke install
I've seen them a few times via video, wanted to try it myself. I love smoke, thought it would be cool to have red, white and blue smoke. The smoke I found is from rcsmoke.com. Four minute duration, my biggest concern is that the white smoke from the turbine will over power the two colored ones. Won't be able to tell until I fly it. I had some controllers that a friend made for me when I was doing fireworks on helicopters. Its a sequencer that will arm and fire four different lines.
I mounted the holder about 5/8" away from the wing, and I will put aluminum heat tape on the fuse and aileron right below it. I doubt the heat will be an issue in flight, but if I had to land while the smoke was going, it could generate enough heat to harm the underside of the wing.
This is on a tomahawk 2m viper. I have the them 4' apart, any farther would have been really tough to glue the mounting blocks inside the wings.
Pretty innocuous when its not on, and takes just two 4-40 bolts to install.
ID:	1902328   Click image for larger version
ID:	1902329   Click image for larger version
