RCU Forums - View Single Post - what to get aeroworks 3dhs
Old 07-20-2013 | 05:13 PM
nitro wing
Default RE: what to get aeroworks 3dhs
The 35 bolts right up and template is provided.i put the dle 35
In mine with canister.
It just needs 1/4 spacers to get cowl
Distance. I simply made them from wood ( 1 inch Diam? )
Dowel and drilled the center out for bolts
Some said the el servos may touch each
If you have a deep case. I had clearance
On mine, but easy enough to use a shim if needed
Everything else was simple.
Enjoy
