ORIGINAL: BuschBarber
ORIGINAL: Rob2160
For some reason I can't edit my earlier post...
Just thinking about multiple RXs bound to the same model memory as per my vid above.. they are all DSM2 Helis..
I wonder what would happen with the newer DSMX / Telemetry BNF helis if you bind more than one at the same time?
Or a combo of DSM2 / DSMX - I'll try it later when I get home..
It is my understanding that if you Bind multiple receivers to the same Model Memory, they each need to be the same Protocol ( both DMS2 or both DSMX). The Model Memory stores the Protocol for the receivers it is Bound to.
Yes, you are right.. I was able to bind multiple DSM2 helis or multiple DSMX Helis to the same model memory and they worked simultaneiously. But I was not able to bind one DSM2 and one DSMX model to the same model memory.. Thought that might be the case but was curious..
