RCU Forums - View Single Post - crsahed DLE30
Old 07-21-2013 | 08:38 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: crsahed DLE30
Depending on where the break is located you may have more damaged parts. If the impact cracked the base of the cylinder and allowed it to pivot forward while the engine was running you may have a bent connecting rod and a damaged lower needle bearing. Have you removed and inspected the crank bearings yet?
