RE: TBM Shock Jet
Jason,
Regarding your question on air brakes. I have done 5 shock jets for myself and others. All using one type of brake or another. Robart brakes and tires or Dr Hondas brakes and Du-bro tires are probably the cheapest way. I have also done Inarcos system . if you use robart then their small "Green" one way valve is all you need and a small servo.( Mn48) or equiv. Using inarco I used a ultra precision " Up-6" and servo. Dr Hondas brakes also work well with a simple valve. I have even put wheel pants on a couple with brakes really classes the shocker up. On one I put wheel pants , brakes and retractable nose gear, and one with full retractable "Pro-link" gear.[img][/img] be glad to send photos etc.
Glenn Sheppard
