RE: TBM Shock Jet
Jason
Like Glenn said we had at least five flying in Nashville at a time.
Mine has robart brakes and wheels put on the stock main gear. Works like a charm.
I put the bottle in the top nose compartment with the ecu battery.
If you still use the stock nose gear solder the cross brace that would hold that brake paddle into the mounts and install it half way up for additional stability.
Its not fancy but adds stability while still giving good flex to save that weak nose gear former, which needs reinforcing!
Cheers
Andy
