ORIGINAL: phmaximus
If cost was not a factor...
Imagin been able to get a 1/8th 1970's (insert u favourite here) muscle car....but...
It has a scale twin rail chassis with 2wd rear live axle and front double wishbone suspension, front mounted north south motor, planetary gear sets for the gearbox and telescopic tail shaft straight to the diff, And has the ability to run either trailing arms or 4 link rear suspension with leaf or coil springs. Also the ability to run mechanical brakes... 4 disc or 2disc/2drum hydraulic brakes
Then a high detailed body with different hood, bumpers, grills, lights and accessories with full cockpit including seats and fuzzy dice... and a full under tray with wheel arches that meets up to the body
This would be fantastic
